Help! my 95 7.3 4x4 wont shift into any gear. - Ford Powerstroke Diesel Forum
Old 05-01-2012, 04:11 PM
ive been reading forums for hours now, and have'nt seen any specifics relating to this particular problem. oil is fine, and tranny didnt slip prior to this happening. could it be the tc? pump? anyone out there had the same prob and can advise?
Old 05-06-2012, 06:41 AM
Transmission or Injectors
A weak pump will not build any pressure, and not shift any gears. I have a small leak in a check valve, and if my truck sits for a while, it takes a bit longer once a gear is selected to actually engage that gear (reverse is longer).
There is a pressure port on the side of the transmission. If you make up a hose with a gauge on it, and thread it into that port, you can see how much pressure there is.
Old 05-06-2012, 05:17 PM
Does the truck stay put in Park?
Old 05-06-2012, 05:26 PM
how much pressure should there be?
Old 05-07-2012, 08:40 AM
Depends on the gear, I can't remember the specs off the top of my head, but should be in the 90-120 psi range
Old 05-07-2012, 12:54 PM
e4od 2-3 shift free revs
Old 05-18-2012, 07:05 PM
Mine did the same thing, TC was fried and the pump was in a dozen pieces, no warnings, no nothing, came to a red light, hit the gas and went no where..... $2200 for a HD overhaul.... money well spent so far!!
