Transfer case problem.... - Ford Powerstroke Diesel Forum
Old 03-17-2012, 09:23 AM
So previous owner got it rebuilt... and it will go into neutral and 4high, but won't go into 4 low, its a 5sp as well....
Sent from my C771 using AutoGuide.com App
Old 03-17-2012, 08:48 PM
On the auto's there is a lockout that prevents going to low without being in neutral. Perhaps that's not setup correctly for your zf5.
Old 03-18-2012, 07:53 AM
Full A-Team Member
Lever pull or switch?
Old 03-18-2012, 04:22 PM
Its hot auto locking hubs and is lever
Old 03-18-2012, 04:38 PM
Full A-Team Member
So you cant push the lever down to pull it back into LO range? you can do 2 things:
1. Take lever assembly off under truck and lube everything up and get it working.
2. Look at lever assembly under truck and you will see a 'roll pin' thru the shaft. That pin is in there only for the 'push down' feature of the lever, if you cut off the 2 tabs of the pin, it will shift freely without having to push the lever down to get into 4LO
Old 03-25-2012, 11:22 AM
Well just figured I'd let ya'll know my stupidity.... I was a little inebriated.... when my 4lo wasn't "working" the knob was upside down duh..... feel like a retard, figured ya'll would get a laugh out of that
Old 03-25-2012, 02:36 PM
Full A-Team Member
That is a knee slapper right there
Glad you got it figured.
Old 03-26-2012, 08:31 AM
Time for a breathalyzer-transfer case interlock......
Old 03-26-2012, 12:52 PM
Full A-Team Member
