A4OD problems - Ford Powerstroke Diesel Forum
Old 02-26-2012, 06:27 AM
A4OD problems
I am new to the powerstroke world. I have only owned my 96 f350 for a few weeks now. The truck has about 212k miles, and supposively the trans was rebuilt a while ago.
The other day I noticed it was slipping from 1st to 2nd. It would run up to about 3500 rpms and hold for a bit before slowly slipping into 2nd. It is also shifting pretty roughly into the other gears. The OD light was flashing. It is also acting like it is in netural at times when placed in reverse or drive. Or acting like the parking brake is on and will barely move.
I changed the trans fluid and filter yesterday and noticed that it runs at a lower rpm now and actually shifts thru all the gears, but still slips and shifts ind of hard.
Any help would be appreciated.
Old 02-26-2012, 08:01 AM
FYI the trans is a E4od. Is the od light still flashing? If it is you need to get the codes pulled, it's not good to drive the truck when the od light is flashing because the trans is in limp mode and builds excessive line pressure. You might try disconnecting the harness that is on the passenger side of the trans and make sure that connection is clean and dry. That connection controls all the shifting. Also is your speedometer working correctly?
Old 02-26-2012, 01:06 PM
ya i meant e40d. it is not flashing at this time. the trans shop was unable to diagose it. it is no longer flashing. and the speedometer is working fine. ill check the connection today
Old 02-28-2012, 08:56 AM
just noticed the speedometer is bouncing a little at higher speeds??
having a trans built now but curious to know what the speedo could indicate
Old 02-28-2012, 10:05 AM
How much is it bouncing? If it's just a couple mph it shouldn't mess with anything but if several mph I would check or change the vss on the rear axle and check the wiring going to it.
Old 02-28-2012, 10:58 AM
its less than about 5mph
Old 02-28-2012, 11:07 AM
You might consider pulling it and making sure it's clean. Your right at that fine line that is, might want to replace it especially since they are not expensive or if you have a buddy with one and try it.
Old 02-28-2012, 11:33 AM
ill look into it, im pretty sure the trans is toast though. getting a rebuilt with aftermarket TC, shift kit, etc for 1400 installed with 3 year/50k mile warranty
Old 02-28-2012, 11:41 AM
That is a good price, about $200 less than my rebuild but the builder did a lot of upgrading and a few extra's. If you don't have one already spend the extra money install a high quality over sized trans cooler.
Old 02-28-2012, 12:15 PM
will do, hes going to do all the updates the trans needs and build it to handle the power/towing. i will look into a trans cooler as well
