5 speed trans only goes into 3rd & 4th gear - Ford Powerstroke Diesel Forum
Old 10-30-2011, 07:14 PM
96 f-250 4x4 7.3 with the 5 speed manual. This one stumps me, the truck will go into 3rd and 4th gear like normal, and i can slip the clutch and drive normally. So I know its not the clutch. But all the other gears are just locked out 99% of the time. But when the truck sits just right, and i mean just exactly right, or maybe its just lucky, it will go into all gears. So if it will go into reverse then it will go into first etc. I dont get it. Im thinking it must be an issue with either a broke/bent shift fork or rail. Any help is greatly appreciated. Thanks
Old 10-30-2011, 07:34 PM
The Tamed Racing Driver
Yeah, sounds like a shift fork/interlock problem.
Old 10-30-2011, 07:45 PM
shift tower?
Pull the trans and tear it apart? I cant get to it from the the shift tower can I?
Old 10-30-2011, 07:52 PM
Not really. You can take off the shift tower and take a look, but to get to anything you'll have to split the case.
Old 10-30-2011, 07:59 PM
Winning DUHHH
Id vote for bent shift fork.
Old 10-31-2011, 09:20 AM
Is it any different rowing through the gears (or trying to, anyway) with the engine off?
When in neutral between third and fourth, does the shifter move smoothly left-right across the H-pattern?
Old 10-31-2011, 09:23 AM
In neutral
In neutral it functions exactly the same as the truck being on. 3rd and 4th are great and the shifter moves left and right like it should. just refuses to go into gear 1-2 and 5th-Rev.
Old 10-31-2011, 02:27 PM
Okay, if it's no better with the engine off, then it's not likely a synchro issue; sounding more like the fork/rail/selector goodies in the top of the tranny. Can't hurt to pop the top off and poke around; maybe something is just preventing the shifter from moving far enough left and right across the middle of the H to allow fore-aft movement in those gates. Cross your fingers it's something simple like that....
