OD Stuck OFF - Ford Powerstroke Diesel Forum
Old 10-25-2011, 03:10 PM
OD Stuck OFF
So last night the OD on my truck was stuck ON essentially because when I pressed the button, it would not go off. Now whenever I start my truck the OD lights up and is OFF. It stays OFF no matter what now, even if I press the button a million times, hold it, etc.... It used to do this randomly, but would go away very quickly when i pressed the button or held it. The OD has also turned off while I have been on the highway, but it is rare that it does it. Now with it being stuck in the OFF position, I can't go on the highway. I checked the button with my meter in OHMs and the button works. I have good power going to the button as well. What should my next step be? Is it a selenoid issue or something else? Could the meter show the button works, but it be faulty somehow? Just trying to see if anyone has had any problems similar to this, any input would help.
SR
Old 10-27-2011, 02:31 AM
Hillbilly Deluxe
Feedback Score: 3 reviews
Like i said before... OD solenoid...
E4OD is completely computer controled. It shifts based on inputs from the solenoid pack and the VSS in the rear diff. Also check your harness for damage, its likely not an issue, but worth a look.
Download my E4OD manual... http://api.viglink.com/api/click?for...13197115352182
Old 10-27-2011, 04:14 AM
Thanks for the help man, I appreciate it.
