shifting late or not shifting smoothly - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-14-2006, 11:20 AM Thread Starter
I have a 97 F 250 with an automatic and overdrive. I was gone last weekend at fort Carson and my roommate was using my pickup. Monday when leaving for Wyoming I jumped in the truck to find that when I would get on the accelerator the truck would not shift gears, it would simply run up to about 2600 rpms. If I leave a stop light and accelerate slowly it shifts. Also it has been shifting from low one to the second gear pretty hard. Any advice would be greatly appreciated. I am really hoping that it is something other than a new transmission in my future.
Thanks
Mike
michande04 is offline
post #2 of 9 Old 06-14-2006, 11:46 AM
Power Strokeaholic
super_stroke's Avatar
RULE #1. NO ONE DRIVES MY TRUCK BUT ME!!* my dad did once when we were at the dealer getin it but still.
check the fluid level if you havent. also maybe change the filter. could be that the fluid is to low and on hard accel. the fluid sloshes to the rear of the pan out of reach of the pick up. ???
* Unless I'm, there then almost anyone can drive.
Bill
2000 f-250 4x4 ex cab 7.3 psd. diablo programmer, TS 6 pos.
, 4" exhaust turbo back w/ 5" stacks, wicked wheel, HX cross over, zoodad mod, 6637 mod, boost pyro & trany on the a pilliar. 315/75/16 bfg mt's,.superwinch hub's, 6.0 trans cooler, banks trans command. sky jacker leveling kit
super_stroke is offline
post #3 of 9 Old 06-14-2006, 12:13 PM
harald@bd's Avatar
This sounds like a sensor issue ,Get a scan tool on it and check for codes.I'm leaning toward a bad TPS, or posibile Nuetral switch out of adjustment.Checking codes will tell you.
Harald Harks
Techinical ,Sales Rep
BD Diesel Performance
1-800-887-5030
2005 F350 Lariet crew 4x4,125,000 miles,BD x-hale exhaust,BD transmission and convertor,BD xtreme air box,Edge platinum, BD x tuner,BD exhaust Brake and Autoloc Pressure lock Combo./1350x 20 Mickey Thompson ATV"S.on Eco 20" wheels
KC Light's,Manik Stainless bushguard,APE Wrap.
harald@bd is offline
post #4 of 9 Old 06-14-2006, 12:36 PM
Power Strokeaholic
could be a sensor but i have a '77 F-100 with a C-6 and it did the same thing and the fluid was low because of a hole in the cooler. replaced cooler and filled it back up and it was perfect. but like he said check for codes.
Bill
post #5 of 9 Old 06-14-2006, 12:54 PM
harald@bd's Avatar
Yes,on your C6 that could have worked well being that it is controlled by vaccum and mostly mechanical.The E40D is total electronic ly controlled trans,it monitors TPS signal and contols shift points based on that signal .
This is not to say servicing the trans would not help with shift issues ,I just believe that the problem is electronic related and checking codes should answer the question.
Harald Harks
1-800-887-5030
post #6 of 9 Old 06-14-2006, 01:12 PM
Power Strokeaholic
agreed.
Bill
post #7 of 9 Old 07-10-2006, 08:53 PM
Stroked95's Avatar
Not to high jack your thread, but the companies work truck is a 96 with an auto trans. Lately, well today and last fri. it has been acting really strange. Last fri I was on my way back to the yard and was on I-5 in OD and all of a sudden it just jumped out of gear like it was in neutral?? So I did'nt know what to do I hit the brakes alittle and gave it the go pedal a little, nothing changed. So I slowed way down and shifted to 2 and that gear worked but drive and OD would not. So I limp it another 5 miles and it completely shuts off on me and I have to wait about an hour to get towed Bad alternator, fixed.
However today on the way home, again, with steady throttle the trans does not want to stay in OD and it sounds like I'm going to blow the motor at 50 mph. But give it just the slightest throttle and it will go into OD, go steady again and it kicks out. It was driving me crazy! Any sugesstions?
1995 Reg Cab F350
totaldieselperformance.comWildman Tuning
terminatorengineering.com Terminator Nation
wideopenperformance
Stroked95 is offline
post #8 of 9 Old 07-11-2006, 06:03 AM
harald@bd's Avatar
Any codes,this could be several different things causing these conditions.
Harald Harks
1-800-887-5030
post #9 of 9 Old 07-11-2006, 08:54 PM
Stroked95's Avatar
There probably is codes but I don't have a scan tool any more, and its the companies truck that I work for. I forgot to add that the ABS light has been staying on also. The boss was saying something about a sensor behind/on the brake pedal that causes the wierd shifting. He is going to take it to a guy who fixed a similar problem in the past.
1995 Reg Cab F350
wideopenperformance
