converter not un locking?? - Ford Powerstroke Diesel Forum
Old 09-09-2011, 05:42 AM
when the truck is warm and coming to a stop the idle drops to 450-500 then back up to normal how can I test to see if it is the converter not unlocking did a test coming down the off ramp I put it in neutral and it does the same thing ??
Old 09-09-2011, 02:34 PM
A scan tool should be able to tell you if the converter is locked. Otherwise, hookup a led to the TC lockup wire to see when it's locked up.
Old 09-10-2011, 10:00 AM
Not sure in my AE how to check it you know how good their instructions are. Anyway I put it in reverse and it died twice??And if I pull it down to low it tries to stall out then jumps back up to 750 rpms I can feel something letting lose when it does it.
Old 09-13-2011, 10:17 PM
cratos, those are classic symptons of a pump with cross leaks. Get the pump replaced before it kills the converter.
Old 09-14-2011, 05:26 AM
ok i have been trying to get a hold of brian I hope I dont have to eat the shipping i have not had it that long. !!
