Installed 4in exhaust today tranny wont go into gear
I installed 4 in exhaust today on my 97 f350 p stroke with an auto tranny, took it out for test drive and got to the corner and went to take off and tranny wouldn't do any thing. I got out shut the truck off and looked for anything looking wrong couldnt find it. they when i started it back up it took off but only for about 100 feet then it acts like the tranny went out. Is it a vacum issue or something?
Never herd of the before. An exhaust install shouldn't have any affect on the transmission. Try unhooking the battery terminals and letting the truck sit for a while to reset the computer. Good Luck
Yeah... this is a first...
I tried to unhook batteries and reset computer but it did nothing, I drove the truck to and from work yesterday w no problems and it's never acted up before the previous owner said the trans was rebuilt about 30,000 miles ago. It acts like it needs back pressure or something it only drove about a half mile so it can't be a temp issue. When it did move at first it acted like it needed to be reved to built enough pressure for it to move. This one has got me stumped and an angry wife!!
Nope i never use the parking brake, It's strange It takes off fine but a little weaker than normal then about 100 feet down the rode the truck revs up because it's like my trans fades away until it just sit's there in gear and revs up like it's in neutral. now it back home and about every 4 time i start it or so it will go into gear but when i back up w it and go to drop it in drive it doesn't move and i have to shut it off and try to keep starting until one of the time it will drop into gear.
It's unlikely it happened so fast, but I've heard of aftermarket downpipes rubbing holes in the tranny cooler lines on these OBS's. I originally put a cheap
MBRP downpipe on my truck, and had to rig up a little something to prevent it from touching the lines. Now I have a full Diamond Eye system on my truck and it fits much better. Sent from my DROID X2 using AutoGuide App |
It never had a chance to rub through I only put it on 2 hours ago and drove 1/2 mile now in the drive way it moves about every 6 times i start it but if i rev it above idle it just revs and stops moving. Do you think my torque converter took a **** that fast just by punching it leaving the driveway, I did'nt have my chip on and I also just installed that last week to it's a ts performance chip.
Maybe its just a huge coincidence...? It's not unheard of. I really can't think of any way that installing an exhaust would affect tranny function
![]() Sent from my DROID X2 using AutoGuide App |
Does anyone know how to check to tell if my torque converter is shot.
