Lost Reverse for awhile!!??? WTF? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-31-2011, 04:47 PM Thread Starter
wyobulldog's Avatar
If you guys have any info to help that would be great! I have a 1997 F-350 SRW 7.3l with an automatic and 210,000 miles. This weekend I pulled my 29 foot travel trailer about 45 miles in a 35-40mph headwind in 3rd gear about 55-60mph. It pulled fine, but when we got to our campsite and I went to back it in the motor bogged down and died. I restarted it and pulled forward and attempted the backup again and same thing happened, then I put the transfer case into 4 low and it backed up fine. I didn't lock the hubs just put the T-case in low and it worked in reverse. The truck sat for 2 days after that and yesterday when I hooked up reverse worked fine and has ever since. I had the tranny and t-case both flushed and refilled with full synthetic and new filter about 2 months ago. Not sure what happened, but I am now worried that I need a rebuild, what do you guys think the problem could be?
Thanks for any info you may have!!
L I V E S T R O N G
wyobulldog is offline
post #2 of 6 Old 05-31-2011, 04:58 PM
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
I have heard that sometimes the filter coming loose will cause the torque converter to try and lock in reverse causing it to stall. Check that first.
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #3 of 6 Old 05-31-2011, 06:07 PM
JD3020's Avatar
I'm thinking its a filter problem also. My truck did that 3 times last summer. I'd put it in reverse, and it'd lock the converter up and kill the truck. Recently it has been trying to lock-up in reverse, but i don't think its the same issue. I've towed a little since then, and even with the chip its still going strong.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #4 of 6 Old 05-31-2011, 07:17 PM Thread Starter
wyobulldog's Avatar
Thanks for the info guys! I hope it is something as simple as the filter. When I had it flushed the guy at the tranny shop said it looked great on the inside with little wear and no damage. The truck is all stock except for a NAPA 6637 filter.
L I V E S T R O N G
post #5 of 6 Old 07-11-2011, 08:53 PM
250dieselboy's Avatar
Send a message via AIM to 250dieselboy
I have the same problem with my 95 f250 e40d trans but it does not kill the motor, it will go through the gears in foward fine but soon as you put it in reverse it goes no where, also if you put it neutral it goes forward, any suggestions?
250dieselboy is offline
post #6 of 6 Old 07-11-2011, 10:35 PM
Quoted: 43 Post(s)
^^^^ That sounds like a range selector problem; thinks it's in neutral when you're in reverse, and thinks it's in drive when you're in neutral.
madpogue is offline
