reverse problems - Ford Powerstroke Diesel Forum
Old 05-25-2011, 11:48 PM
reverse problems
i have a 96 f250 with an older 5 speed in it my clutch was pretty wore out and my reverse gear started popping out i replaced the clutch and it still did it so we opened up the the tranny no chipped or broken teeth syncro looked fine detent spring wasnt in the best shape so we fixed that but it still keeps popping out of reverse im at the end of my rope does anyone have a clue as to whats going on
Old 05-26-2011, 06:28 AM
Had the same issue in a old 95 F150 when i tore into it the syncros looked fine but upon a closer inspection and talking to a tranny shop they said to pull them out and check and make sure they were not rounded over. It was a easy fix just took a file and cleaned everything up again. I also had a issue with the Shaft that holds the second bunch of gears. It had spun in the bearings so it had to be replaced. Just went to the scrap yard for the parts i needed. Took a chance and bought a core tranny... lucked out their was nothing wrong with it not even sure why it was in the core pile
Old 05-26-2011, 09:31 AM
Thanks ill have to try that out im just sick ofthe constant let down of failure haha
