Best Trans Cooler
Which trans coolers do you guy use im going to upgrade mine and help save my tranny as long as i can Thanks Guys and Gals
trans cooler from a 6.0L, but idk if it fits into a obs?
The 6.0 trans cooler is the best redily availible cooler out there however if you can find one a militery trans cooler for a HMMWV is the best I have ever found and is what I run. It takes a lot to make it fit thougth, it is nearly the size of an intercooler.
well i found a kit up at the local parts store i liked and took the old one out and replaced the tranny oil lines and put her on there test drove it and found that the factory clamps are leaking just a little and gonna replace those and take some pics it worked out just fine now i need a temp gauge to tell if i did any good cuz there is already a trans cooler in the radiator
Try this :
transmissioncoolers.us: Tru-Cool MAX transmission cooler *No external cold weather thermal bypass I just put one on my OBS....mounted it right behind the grille...had to Dremel out the back of the grille, but it worked out fine.... you will also need to extend the hood safety latch release lever...no biggie.... |
Ya it does!
my cooler is cooler and trumps your cooler
