od light started to flash - Ford Powerstroke Diesel Forum
Old 12-11-2009, 10:12 AM
what problems are associated with the overdrive light flashing?
Old 12-11-2009, 03:49 PM
all problems. Light flashing means the computer has seen a problem. 1 or 2 or 3 or100.
Old 12-11-2009, 04:01 PM
Shaking the Bush Boss
deffinatly get the codes pulled...could be as simple as the speed sensor in the diff going.....
Old 12-11-2009, 08:34 PM
my uncle is gettin a snap on scanner hopefully tomorrow and i think it may be the tc because of its functions while driving. if it is the case do i need to get a whole trans or can i get a tc and fix it
Old 12-12-2009, 05:19 AM
If it has just started and if the trans pan has no metal in it, then you may be able to get by with jus t a converter.
Old 12-16-2009, 04:02 PM
got a code P1728 and its about a converter fault. electrical maybe ?
Old 12-17-2009, 11:21 AM
to the top
Old 12-17-2009, 01:08 PM
What do you mean,,"to the top"??
Old 12-17-2009, 10:00 PM
bump? lol my bad
Old 12-17-2009, 10:03 PM
scuffs *****
Send a message via AIM to Tyler
Whats it doing when the lught flashed shifting wise/
