How much line pressure
I have a 1996 F-350 Diesel with E4OD tranny. How much line pressure should there be at idle and when I gas it..Thanks
60 to 65 at idle in dr. 150 to 180 at wot in dr. Rev is higher.
when I data stream with my programmer it is saying 5 at idle in park and drive, if I rev it up depending how much, its saying 35..Does that mean my pump is bad or could my cooler be blocked?
It means your data stream programmer is fos. The vehicle won't even move at 35 psi. You need to hook a guage to the trans. Needs to be at least a 200lb guage. There is a port on the drivers side about 6 inches in fromt of the liknage. It looks like 7/16 bolt. The thread is 1/8 pipe.
ok, thanks alot..Ill have to try that
