Have you ever................... - Ford Powerstroke Diesel Forum
Old 11-16-2009, 07:21 PM
Send a message via AIM to tsteel
Im sittin here just thinking and playin online and had a question for EVERYONE!
Has anyone ever used the stop slip or some sort of additive in there trans to keep it from slipping?
If so what did you use and tell us how it worked!
I never have used the stuff but just curious as you see a ton of it at the parts house when you go up there.
Old 11-16-2009, 11:51 PM
yes. I used the Lucas tranny fix stuff in my old explorer. Gave me another 20K miles before I had to rebuild it.
Old 11-17-2009, 02:43 AM
the lucas stuff works great, i'd use it even if it wasnt slipping (atleast a little bit) to help keep everything lubed the stuff works great
Old 11-17-2009, 03:34 AM
All any of those additives do is swell the seals and o-rings and the friction material on the clutches. That is why you get a little extra before the let loose. They do what they are designed to do for a trans with problems but I wouldn't recommend using them in a good trans.
Old 11-17-2009, 03:49 AM
unless its a E4OD, then is should be filled with nothing but lucas lol pita fubar pos I wish I had a 6 spd.
Old 11-17-2009, 07:44 AM
Thanks guys. I was just curious.
Old 11-27-2009, 03:04 PM
When my tranny started to go I put half a bottle of the lucas stuff in it and the other half in my uncles full size chevy blazer that had a slipping 4l60e, my tranny went out completely the next day and his first lost 2nd and od then it lost all forward gears in less than a week. I'm NEVER putting that stuff in ANYTHING again.
Old 12-11-2009, 04:19 PM
There is only 1 additive to use. Lubeguard. It doesen't fix anything, just makes the fluid do a better job.
Old 12-11-2009, 04:38 PM
What about oil additives? Any body use them?
Old 12-12-2009, 05:04 AM
I run synthetic eng oil in alll my vehicles and use the Lucas synthetic additive but only 1/2 the amount they recommend.
