New trans install - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-14-2009, 07:24 PM Thread Starter
New trans install
I purchased a new trans for my 97 f 250. The guy I purchased the trans from is allowing me to install myself. Provided I follow his instructions to the T. The only issue that I am having is, his instructions say that the timing marks must be lined up. Is he asking me to make sure that my crank and cam are lined up? If so how is this accomplished on my powerstroke? I need help, I need to have this project finished tomorrow. No way to get in contact with my builder until monday
Thanks: J almont
J almont is offline
post #2 of 7 Old 11-14-2009, 08:04 PM
coaltrain444's Avatar
What he probably means is to line your torque converter to your flywheel. Some people say you need to line them up but it really don't matter. As far as the timing marks on your engine I see no reason why this would need to be done plus you can't really adjust it as it's EEC controlled as far as I remember. I just got do e installing mine it's pretty easy. Any more ?'s
coaltrain444 is offline
post #3 of 7 Old 11-14-2009, 08:41 PM Thread Starter
I figured it was something like that, could not for the life of me figure out the relation to engine timing. Having said that I looked for marks on the converter and saw none. Trans ready to drop in the morning will pay close attention as to how it comes apart.
Thanks for the info
J almont is offline
post #4 of 7 Old 11-14-2009, 08:47 PM
I'd just take a marker or white out and mark the flywheel and converter for easy placement. Do you have an aftermarket cooler for the new trans. If noti would get one. A decent small one is available on eBay for like 35 bucks with mount kit. Look up Hayden 1404 or even a Hayden 1405 would be good. Good luck
post #5 of 7 Old 11-16-2009, 12:53 AM
speeddemon31176's Avatar
You should never ever install a new transmission without installing a new torque convertor. Be sure to flush out the cooler lines as well otherwise you are wasting your time installing a new trans. I would love to know what timing marks have to do with trans install. I have never seen any indication of clocking the convertor a certain way for the install. Since the convertor is not balanced to be installed a certain way how would there be a special way to install it?
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes next.
speeddemon31176 is offline
post #6 of 7 Old 11-16-2009, 01:03 AM
Powersmokein's Avatar
dunno, lol hope it turns out well for ya. just got done dropin rebuilding and reinstalling the trans. from my wifes Honda.........dear god...... never messed with a automatic that was that much of a PITA
'97 F350 CC LB
Originally Posted by Twinjracing View Post
Now that's F****ing Balls Do they clink as he walks???
Originally Posted by alberta 7.3 View Post
but I guess the porno red interior made you lose interest
Powersmokein is offline
post #7 of 7 Old 11-16-2009, 01:17 PM
Gruss's Avatar
Only thing I can think of would be making sure the drain plug for the tq. converter is aligned with the hole in the flexplate.
"If you want smoke, work for it. These guys did" JJFLASH
Stormtrooper:: 1997 F-350 CC SRW PSD XLT 4X4: Baby Swamps, Wildman 4 pos chip, 120V IDM, SD Intercooler,BTS E4OD, RSK, CCV mod, shimmed FPR, DIY 6637 air filter, triple pillar pod with Isspro gauges, 4" MBRP exhaust, SD dual tensioner,
Gruss is offline
