trouble getting into gear zf5 - Ford Powerstroke Diesel Forum
Old 11-13-2009, 07:30 AM
after I reverse, or if im sittin still, its really really tough to get the truck into reverse or first gear.
in order to get it into reverse, you gotta pull real hard then it makes a metallic clunk and goes in. first, it makes like 2 clunks when it finally goes in.
I think its a problem with clutch release issues. I have to have the clutch all the way on the floor to shift gears, and even then, I know its a HD truck trans, but I dont think it should be that rough.
if I let the revs drop and rpm match, it goes in smoother. so thats why I am thinking release issue.
also, its not leaking, and I think my dual mass is startin to take a poop...so theres extra diagnosis info.
Old 11-13-2009, 02:20 PM
Shade tree mechanic
check this vindeo out... this was my problem. I had the exact same symptoms as you...
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
After fixing the clutch pedal bushing mine shifts perfectly now. Hope it helps.
Old 11-13-2009, 02:39 PM
PMR = JUNK
I agree with the bushing, but don't take much else that guy says seriously.
The powerstroke help guy not Matt.
Old 11-13-2009, 03:14 PM
Shade tree mechanic
I agree. That guy is a little whack on alot of stuff he says... that video of the clutch pedal bushing is the only video I have found usefull
Old 11-13-2009, 03:26 PM
PMR = JUNK
Don't ferget ta chanje yer HPOP awl.
Old 11-13-2009, 06:19 PM
thanks guys. ill check that bushing out tomorrow
Old 11-14-2009, 03:40 PM
i pulled the bushing out in like 3 pieces. it was worn down, and the eye on the master cylinder rod was starting to oval out.
i popped in a new bushing, and the freeplay went completley away. havent driven it yet, but I will tonight. hopefully things will be nice and smooth.
