Reverse slow to engage 95 E4OD? - Ford Powerstroke Diesel Forum
Old 11-01-2009, 07:49 PM
Well guys I know I have seen it posted before but can't remember what the fix was. When I put it in reverse it takes 10 seconds or so to engage then its fine. If I run the rpm up to 1100 or so it kicks right in but with the shift kit adding line pressure, the red eagle clutches, and higher pressure pump I put in when I built it she goes in with a BANG at 1100 rpm!!
So what is the fix guys?
Old 11-02-2009, 10:30 PM
No input guys?
Could it be the manual lever position sensor?
Old 11-03-2009, 06:30 PM
Mine does the same thing.... ANYONE??
