'96 e40d problems???
'96 ps e40d 4x4 About 6 months ago, I had tranny issues....truck didn't want to shift from 1-2. Someone suggest changing speed sensor...sure enough, the sheath had come off and was mushroomed. Pulled rear diff. cover and replaced...worked good for a while. Now, doing something very similar, when tranny warms up, doesn't want to shift 1-2. Doesn't do it when cold. When it acts up, if you stand in the gas, it doesn't want to shift (not slipping), but if you baby the gas pedal, it shifts smoothly. Could this be solenoid or valve body? Is there a good, over the counter, scanner i can buy instead of trailering it back to town?
*This is my ranch truck, not driven on highway anymore. Also, my OD light broke off long time ago, so don't know if it is blinking. |
Give you a
here. I'm not sure exactly what the problem is. I can work my way around a motor, but automatic tranny's are a whole different beast altogether. OBD II scanners are available at Auto Zone. IIRC, they're around $200. You can either buy and keep the scanner, or buy/ use/ then return the scanner. Personally, I'd just buy it. mike |
Do a search on here for eratic efod shifts. I read something about the trans fluid temp sensor not reading right and causing similar problems. I think you will need more than a 200.00 scan tool though. I dont think those cheap ones can pull a data stream so that you can see for sure.
It's going to be hard to guess without the ability to see enhanced data and trans codes, but check fliud level, could be low internal pressure-low to intermediate clutch, could be an issue with S2 solenoid, valvebody could be loose, 1-2 shift valve could be sticking,D2 valve could be sticking or have a broken or damaged spring, interermediate clutch accumulator reg. valve sticking, intermed. clutch accumulator sticking/damaged springs,intermediate clutch assy. piston seal could be leaking, check baal in intermed. piston could be sticking, feed bolt loose,clutch hub damaged,intermediate one way clutch could be going south, Whew!
i have a 4x4 96er myself with an auto. i had sort of the same problem years ago, when my fuel pump died and i replaced it, the shifting got a lot better. suggest looking at your fuel system. specificly, fuel pressure.
how does fuel pressure affect trannie shifting?
this is weird....I recently started having fuel issues. Truck would shut off while driving. I would stop it, put in park and it would start right up. Then it acted like it was out of fuel with a quarter tank in it.
How does one have an affect on the other? Not doubting you sldghamr, but I can wrap my mind about that one. |
fuel pump
OK
You do mean the external fuel pump on top of the motor? Should and what is the best way to check fuel pressure? |
there is only on fuel pump on the 7.3L PSD, the OBS pump is on top of the engine between the fuel filter and turbo. i would suggest having it checked to just to rule that out, as to how to check, i don't know.
[QUOTE=cincolomas;1448499]this is weird....I recently started having fuel issues. Truck would shut off while driving. I would stop it, put in park and it would start right up. Then it acted like it was out of fuel with a quarter tank in it.
How does one have an affect on the other? Not doubting you sldghamr, but I can wrap my mind about that one.[/QUOTE That problem sounds like a CPS-cam pos. sensor, fuel pressure is checked on the drivers side of the fule filter housing, there is a shcrader valve on the pressure regulator, install pressure gage, like to see 50 to 80 lbs at full throttle/load |
