5sp manual tranny fill plug seized, HELP?
Kind of a lame (theoretically simple) problem / question. I have a 95 f250 diesel w/ 5sp. The tranny fill plug is totally stuck and I'm starting to tear it up trying.
Any suggestions? Would heat be good idea and safe? What is next option if/when I totally strip the fill plug head? Help!!!!!!!!!! |
i had the same problem.you need a 6 point shallow socket, if you use a deep socket it will tend to wanna strip more. Take your time, if it starts to slip STOP.. i sprayed it with some pb blaster and let it sit, heated it up with a tourch and still wouldn't come off at first. try using an open ended wrench too and see if that does anything. tap it with a hammer to try to break it free, but use caution.
Hey thanks for the reply.
I was pretty sure I needed that 6pt socket. however, I didn't have one in that size... tried to 'get by' with what I had. Hope I didn't toast it too bad to get it out with the correct socket. I'll try the torch tomorrow too. I just wasn't sure if there was any reason it would be unsafe there. WTF will i do if 6pointer shreds it too? Hopefully I won't have to find that out. |
As stated above. Saturate that thing with PB blaster and let it sit for a day.
Thanks for all replies.
I think the extra day or two of soad helped, but the correct 6 point (vs 12) really seemed to make the difference. Got it out! Thanks. |
