Hard/delayed/erratic shifting E4OD - Ford Powerstroke Diesel Forum
Old 08-23-2009, 01:09 PM
I happen to have a neighbor who is head of the service department as well as a master certified Ford tech of 15+ years. I had some issues with my trans and some hard/delayed/erratic shifting. He got online and went to Fords version of Alldata and got me all the diagnostic procedures for checking the trans fluid temp sensor since I was throwing a P0713 code. Did all the tests, checked out to be the sensor, replaced it this afternoon and it's all back to normal now.
It's not all that complicated to do but you do have to drop the trans pan and removing the solenoid body makes it easier since you can do it on the bench. No special tools and it's a plug and go procedure. Also I have the part number for the sensor if anyone needs it and it is not as expensive as I thought it was going to be coming from the dealership, $18 out the door. Do not let anyone tell you you have to replace the entire soleniod body as I was told by a number of trans shops as well as some other Ford techs and some people online.
BTW this was for the truck in my sig.
Old 08-23-2009, 11:11 PM
Send a message via AIM to tsteel
good deal!
Old 09-05-2009, 09:27 AM
My truck has been doing something similar. I have been getting a delayed 1-2 sometimes. It does not do it all the time. I did drop my pan and found more friction material in the bottom then I would have like to see . Any thoughts?
Old 09-14-2009, 07:25 PM
Send a message via MSN to pwrstroke247
My truck is doing the SAME exact thing! Did your truck have a check engine light on?.... mine does not......??
Old 09-14-2009, 07:28 PM
no CEL or flasing OD light. It did have a soft code though.
Old 09-14-2009, 08:04 PM
[QUOTE=Hard/delayed/erratic ...[/QUOTE]
Thought you was talkin about me.
Old 02-04-2010, 12:41 PM
Do you still have that part #? I'm fighting the same fight and everyone is telling me I have to get the whole pack....
Old 02-24-2010, 05:28 AM
what casues the hard shifteing in the first 2 gears and the od drive light to flash non stop im havin the exact same problems with my e40d and slight overheating
Old 02-24-2010, 10:59 AM
If you're getting the shifting problems and an OD light you more than likely have an internal problem (clutches or burnt converter) If you don't have the ability to read the trans codes take it somewhere, but you're prob looking at a rebuild....
Sorry for the bad news
Old 02-25-2010, 05:34 AM
dang thats gonna be fun not! its got an appt. at the tranny shop the first of march so well see how that goes. and im supposed to pull a trailer this saturday lol
