clutch replacement - Ford Powerstroke Diesel Forum
Old 07-11-2009, 02:35 PM
clutch replacement
I am going to replace the clutch in my 97 f-350 I have added a Bully Dog 6 pos. chip ,Afe air intake, 3" downpipe , 4" exhaust I am looking at a Southbend clutch for 350 hp. is this enough or should I go with the 450hp. I do pull alot of heavy loads also thanks chad
Old 07-11-2009, 02:41 PM
If that is all of the power that you plan on haveing then the 350 should be good. Are you geing a single mass kit too. and just fyi i got a sb 550 clutch and my buddy with a supper duty got the 350ph rating and i have a true sb and sb just sent him a luk set. You shoul look around all over and find the best price. if you fing the bigger clutch for the same pice it is a no brainer but good luck man.
