Reverse shudder when hot. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-01-2009, 11:16 AM Thread Starter
Armalite's Avatar
Okay got a 96 f-250 7.3 with 191k on it (e4od rebuilt about 4 years ago). The transmission never has slipped and the torque converter works fine. It stays locked at the right times and unlocks perfectly. The transmission shifts thru all gears fine and never slips.
I added a bigger cooler (trucool) and now my transmission never goes above 140degrees. But now I have a strange problem. When the transmission is warm (130-140degrees) and I come to a stop and put the transmission into reverse and give it some throttle there is a very noticeable shudder for about 3 seconds then its goes away. If I stop then keep it in reverse and take off again it dosent happen. Only happens when I shift from drive into reverse. Shifting into drive and giving throttle is fine, no shudder at all.
I did have a problem last year with the stock cooler and having the transmission getting to 160-180degrees and not engaging in forward gears but keeping reverse. I have seen alot of people with that problem of losing forward gears and keeping reverse, but never regaining them like I have... About 5 times.
So yah quick summary...
-When warm (140degress) shifting into reverse gives a shudder for a few seconds.
-Forward is perfect, and shifts perfect.
-Last year I lost forward gears about 5 times when it got around 160-180, kept reverse. But I regained my gears when the tranny cooled down.
Armalite is offline
post #2 of 7 Old 10-09-2009, 01:35 PM
did you figure out the prob? sounds similar to my prob
TuffF150 is offline
post #3 of 7 Old 10-09-2009, 01:38 PM
If it aint a CAT itsa DOG
dieseldan2005's Avatar
Sometimes i get a shutter in reverse in mine after i've been towing on a warm day and i go to back up my trailer. It feels like you are slipping the clutch on a manual trans. I just had my trans rebuilt this spring and i think it still does it.
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #4 of 7 Old 10-09-2009, 01:42 PM
mines new too, brand new! 25miles tops new triple disc converter seems like its slippin in reverse
TuffF150 is offline
post #5 of 7 Old 10-09-2009, 01:53 PM
I wonder if it is something else. I thought it was the same thing on my truck.
Diesel Dan
post #6 of 7 Old 10-09-2009, 01:53 PM
I do remember now that the trans guy told me that my reverse clutches were burnt pretty bad.
Diesel Dan
post #7 of 7 Old 10-09-2009, 04:50 PM Thread Starter
Armalite's Avatar
Wow reply's lol. I kinda forgot about this thread.
But no, I haven't figured the problem out. Starting to get colder out here in jersey so I'm just running it till something happens/again.
Armalite is offline
