What years of Transmission
Hello every one in Ford land, I have a 1996 F250 Powerstroke with an E40D Transmission and it has decided to not work I am NOT willing to keep the Transmission and am going to put in a standard, what I need to know is what years of truck can I swap out part I need?
Thank you for your time.
any zf 5 speed truck will work if it a diesel engine for a donor , there are quite a few years even in gas trucks that the pedals and inside stuff are the same
Thank you for your reply, I have been looking at 92-97 trucks
Could a ZF-6 bolt up to an OBS? Wanted to do that to my '94 before I sold it.
M813 welcome to the .ORG. Let us know how the swap goes. Post pics if you get a chance.
Craig |
yes it will bolt up, be more to make it work on the hydraulics end of it but yes it will |
ZF 5Spd
Well it is all done I swapped out my E40D for a ZF 5spd, there was little bit of work but in three days itr was all done. The biggest thing was to get a Diesel ( a1996 powerstroke). this saved a lot of time and money as all the parts where in the truck, I looked at a 1994 and that is the year of change over, so I found a 1996 F250 4X4 and the rest is history. All the hole where there, wiring etc,. If any one else does this you need the ECU, and IDM, my old ECU I am going to Ford and get it re programed. Thank you all for your info.
i know this is old but i have some questions of my own...I found a zf5 trans that came off a 88 460...guessing that wont work?
No it won't.
a 460 ZF 5 os the exact same as a diesel zf 5 except for the internal gearing is all
