'95 Ford 7.3 Powerstroke - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-17-2014, 08:29 PM Thread Starter
I have a '95 Ford F350 Powerstroke 7.3 Turbo. It runs great until the "Fuel Filter" light comes on. When the light comes on I have about two to four miles to get home or the truck will die. I have a new fuel filter and a new fuel pump in the truck and I can't figure what is wrong with it. It acts like it is runnimg out of gas. I had to have it towed home 5 times last year. I would appreciate any help you can give me.
'95 Powerstroke 7.3 Turbo is offline
post #2 of 5 Old 04-18-2014, 05:36 AM
Quoted: 3 Post(s)
Have you measured the fuel pressure at the Schrader valve on the filter bowl?
Given a new filter and a new fuel pump, it sounds like a problem upstream.
There could be an obstruction in the fuel line from the tank or in the fuel selection valve. It also could be a problem with the pickup mechanism in one of the fuel tanks, but switching tanks should bypass it if that is the problem.
Make sure you don't have a problem with microbes clogging up the system. If so, it can be cleaned up with BioBar found at marine dealers. If so, it may take a few fuel filters before all the bodies are removed.
Airstreamer67 is offline
post #3 of 5 Old 04-18-2014, 05:37 AM
Quoted: 43 Post(s)
^^^^ Does it happen on both tanks? How much fuel is in each tank?
madpogue is offline
post #4 of 5 Old 05-20-2014, 12:06 AM Thread Starter
The front tank was full when I quit using it a year and a half ago because it would die every time I would use it. The back tank has 3/4 tank of fuel and now it says "Fuel Filter" and then dies within 1 to 2 miles.
post #5 of 5 Old 05-20-2014, 02:07 AM
97_stroke's Avatar
Almost sounds like there is a restriction back by the tanks somewhere or maybe the selector valve. Maybe take your feed line off and blow back towards the tanks with compressed air and see what happens.
97' F-250 extended cab 5-spd, 4" AFE exhaust, Tymar cold air intake, guages, Modified IDM, Stage 2 injectors, Complete fuel system, TS 6 pos. chip, Southbend Con OFE clutch, D66 turbo - Gone
08' F-250 CCSB, Spartan 275 tuned, exhaust, S&B CAI - Gone (miss it)
2007 -duramax (who cares)- Gone!
2002 -F-350 CCLB - Gone
2013 - F350 CCSB 6.7 Here!
97_stroke is offline
