Leaking manifolds - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By 97Strokin'
post #1 of 7 Old 04-08-2014, 04:21 PM Thread Starter
97Strokin''s Avatar
Leaking manifolds
My 97 obs started leaking today between the manifold and the up pipe on the driver side and its bad i lost 5-7 pounds of boost is there a way to get it to reseal? Did something break? What should i do?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
97Strokin' is offline
post #2 of 7 Old 04-09-2014, 09:59 AM
duck fan's Avatar
Double check the bolts. That's about the only thing that could break causing the connection to separate. Either that or a hole is rusted in the pipe but I've not seen that happen before.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 7 Old 04-09-2014, 12:00 PM Thread Starter
97Strokin''s Avatar
I found it bolts broke
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #4 of 7 Old 04-09-2014, 02:20 PM
duck fan's Avatar
At least its an easy fix.
duck fan is offline
post #5 of 7 Old 04-09-2014, 04:05 PM Thread Starter
97Strokin''s Avatar
Is it a pain to get there?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #6 of 7 Old 04-10-2014, 10:47 AM
duck fan's Avatar
Driver's side is much easier than the passenger side. There is plenty of room to work with and you can actually see what you're doing.
duck fan is offline
post #7 of 7 Old 04-10-2014, 12:39 PM Thread Starter
97Strokin''s Avatar
I did it today put stainless bolts in and sealed her up
duck fan likes this.
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
