will not start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-27-2014, 05:50 AM Thread Starter
will not start
I have a 95 f350 dully 7.3 I started on Monday it started right up I walked to the mailbox letting the truck warm up half way I heard it shut off and it would not start back up I have replaced the cps / idm I have checked the oil level its good I have cleaned the ipr I have checked the fuel level its good I have checked the fuses under the hood I will check the oil level in the hpop today will I get home but other then that I am lost I do not want the keep throwing parts at it please some help I need this truck bad
randy306 is offline
post #2 of 4 Old 03-27-2014, 07:33 PM
Quoted: 43 Post(s)
First, make sure the PERIOD key on your keyboard works.
Next, is the WTS light coming on? Does the tach move when you crank it? Do you get any smoke from the tailpipe as you crank it?
Did you check the fuses in the interior fuse box?
How much fuel is in the tank that you're currently set to? Did you try the other tank, just for S&G?
madpogue is offline
post #3 of 4 Old 03-28-2014, 02:54 AM Thread Starter
Still won't start
Yes all of that is fine.Wts is coming on.
randy306 is offline
post #4 of 4 Old 03-30-2014, 06:00 PM
Axlesteel's Avatar
Garage
Talking
Try plugging it in for about 6 hours or so and try to start it... Mine would only start if she was plugged in and the solution was new injectors.... im not saying jump straight to injectors but i would try plugging it in.
1997 F-250, SD Axle Swap Front and Rear, 4.10 LS, 20x10 -24mm, 35x12.50 Thuderers, E4OD W/ Shift Kit, Upgraded Torque Converter, Upgraded Trans Cooler, Ladder Bars By Me, TS-6, Baby Swamps, 3" DP to 4", 6637, PHP Tuning, Gauges, and A Lot of Lightbars!
Axlesteel is offline
