U0106 fault! someone help me? what is wrong? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-23-2008, 12:21 PM Thread Starter
I got a 1996 Ford econoline e-350 7,3td powerstroke and i have startings problems when its cold.. i dont get any voltage to the glow plugs..
These are some of the fault codes i get:
U0106 Lost communication with glow plug control module
U0101 Lost communucation with TCM
P1143 Air assisted injector contol valve range/Performance
P0196 Engine oil temperature sensor range/performance
P0443 Evaporative emission system purge control
P0445 Evaporative system leak Detected (large leak)
What can be wrong and wich part do i need to change? What is the the TCM?
The most important is to get the glow plugs to work again.. would it be enough to change the relé maybe? or is there annother control module?
Thanks!
janskii is offline
post #2 of 7 Old 11-23-2008, 05:58 PM
TCM = Transmission control module .. I think
I would run a hot jumper wire to the relay to check it's function. If it doesn't click when you jump to one of the little terminals on there (I forget which one), then it's bad.
The P0443 and P0445 should not be errors that a diesel has. There is no evap system on a diesel (I think). I don't know what to think about those codes.
EOT (engine oil temp) is on top of the high pressure oil pump reservoir (above the water pump). Check it's plug, or better yet check it's resistance (sombody on here could probably tell you what's normal, I don't have my SM in front of my right now). If the computer *thinks* the oil is hot, then it won't necessarily run the glow plugs. This could be part of the problem.
Now, U0101, I don't know about that either. Are you sure a rat hasn't wreaked havoc on your wiring harness? Some of these errors are just weird. I have never seen some of them before on a diesel.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
post #3 of 7 Old 11-23-2008, 06:05 PM
bluepowerpoky's Avatar
im haven the same problem with mine but no codes. if i plug it in its fine though
'96 F-350 dually 7.3 powerstroke, Afe intake, straight pipe, tonywildman chip
bluepowerpoky is offline
post #4 of 7 Old 11-23-2008, 06:14 PM
ADMIN AND TECH
SCUFFY828's Avatar
none of those codes make any sense for a 1996 7.3 van , it doesnt even have a tcm , glkow plug relay is probably why it doesnt want to start, but the codes dont fit that van
ITS STOCK
SCUFFY828 is offline
post #5 of 7 Old 11-24-2008, 12:26 AM Thread Starter
I've had 125 error codes, so I think there are many wheird codes yes :p
Could someone tell me where the glow plug relay is placed? there is a little box on the left valvecover.. might it be under this?
I'm also thinking that maybe the water temp and oil temp sensor can be bad? if these are controlling the glow plug relay? I had a error code on both..
janskii is offline
post #6 of 7 Old 11-24-2008, 04:38 AM
The glow plug relay is located on the passenger side valve cover, sort of beside the fuel filter housing. You can most easily reach it from the back side by removing the dog house, and turbo shield. If your truck still has the silly resonator box on the intake system, remove it with a claw hammer (in pieces) and plug that hole with a paint can lid or bearing cap or something. It makes service a heck of a lot easier.
If you don't want to remove the resonator the fun way, then loosen the bolts, and try to wiggle it out of there while grinding your knuckles on every sharp folded edge, screw, turbocharger piping, etc till you get it out. Your choice.
125 codes??? At one time? I think the most I ever had was on an '08 duramax ambulance I had that had a battery cable loose, and the truck had a nervous breakdown. It threw 38 codes simultaneously, and the tranny wouldn't shift out of first gear. All for a battery that wasn't connected.
Anyway, I was wondering if your PCM is faulty. It seems to be throwing codes for all sorts of things that are unrelated, and even more strange, things you don't even have.
post #7 of 7 Old 11-24-2008, 11:44 AM
POWERSMOKIN's Avatar
i have a feeling he isnt using the right scanner and its scanning on a newer model gas engine.
~Mike Lewis
1996 F-350 CC LB PSD
Beans Stage 1's - 6637 Intake - SD HPOP - 5" Exhaust
E4OD w/ Shift Kit - Sky MFG Reverse Shackle
265,000MI
POWERSMOKIN is offline
