97 F250 won't crank - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-20-2014, 04:33 AM Thread Starter
Dickey's Avatar
Garage
97 F250 won't crank
I just recently got a 1997 F250 with 300,000 on it.
I got the truck with the Transmission already out.
I was told that some trucks won't start with the tranny out but some will. I'm getting it rebuilt, but when I turn the truck over to try to start it nothing happens, besides the batterie needle moves fuel moves an wait to start, radio an A/c that works on it turns on so I have power to it.
But the truck doesn't make a sound.
Is it normal that when you turn the truck over you can't hear the fuel pump?
2014 Harley Davidson Big Blue Pearl Street Glide
Alpine fairing speakers
12" Ape Hangers
2006 Ford F350 King Ranch
BilletProof Oil Cooler Kit
APR Studs
Coolant Relocate Kit
Blue Spring Kit
New Motorcraft Injectors
8" lift kit 38x13.50x18
STC Edge CTS monitor
w/ Vivian tunes looney tune
5" Exhaust 8" Tip
APE Cold intake
50" Ridge Light Bar
Harley Davidson Black Headlights
Dickey is offline
post #2 of 5 Old 03-20-2014, 05:27 AM
Quoted: 58 Post(s)
It doesn't need the transmission. It does need to have the neutral or clutch (depending on tranny type) safety switch bypassed.
Did it have an automatic or manual transmission?
The engine is louder than the fuel pump. If you're thinking you'll hear an electric pump run when you first turn the KEY, before turning the engine over, there is no such pump.
madpogue is offline
post #3 of 5 Old 03-20-2014, 08:47 AM Thread Starter
Dickey's Avatar
Garage
The guy I bought it from said that when he starts it it will drive fine, but when it gets to normal tranny temp it wouldn't pull it's self anymore. So he took the tranny out.
It's a auto
I do believe it's a E40D.
Now I have the tranny in my truck I hate to spend the money to get it rebuilt if there isn't anything wrong with it.
12" Ape Hangers
APR Studs
Blue Spring Kit
5" Exhaust 8" Tip
APE Cold intake
50" Ridge Light Bar
Dickey is offline
post #4 of 5 Old 03-20-2014, 09:41 AM
Quoted: 58 Post(s)
Yes, it's an E4OD (aka E4OhDear, E4DOA....).
So does that mean you've re-installed it? Did you connect the trans range switch/sensor? If that means something else, if the tranny is still out of the truck, you need to determine which two terminals on the TRS connector are for the starter safety lockout (no access to my EVTM during the day, sorry), and jumper those two terminals.
Other option, just to test it out, is to turn the key to RUN, and jumper the starter relay on the passenger-side inner fender.
madpogue is offline
post #5 of 5 Old 01-12-2015, 06:09 PM
Same problem, drove my buddies around farm for an hour, 30 minutes one day and 30 the next week. Backed it off the trailer, let it set for three days, and no crank what so ever. One click in the solenoid when key is turned is all. Replaced solenoid, starter, alternator, and both batteries, engine is not locked up. Possible electrical issue?
jessertaylor23 is offline
