rough idle slow acceleration HELP PLEASE - Ford Powerstroke Diesel Forum
post #1 of 15 Old 03-17-2014, 05:29 PM Thread Starter
ok i have a 97 f350 7.3l. it sat for 7 years. finally got the nerve to pull it out and get it running. i did a buzz test on the injectors and it was good. i replaced the valve cover gasket due to a burnt wire and no change. i cleaned out the back pressure sensor tube and no change. what do i need to do next. the truck has a hard time to start the first time and then it fires right up after that. it idles rough and when i hammer on it. it just drags and slowly raises. but when it warms up. it kinda idles a little better. but still vibrates. what do i need to do. thanks for any help.
jrdnschmdt08 is offline
post #2 of 15 Old 03-17-2014, 07:14 PM
kraker829's Avatar
Do you have access to codes? How is the fuel system? Any rust? Did you change cps? Also need to check icp and ipr..
kraker829 is offline
post #3 of 15 Old 03-17-2014, 07:37 PM Thread Starter
yeah. it would throw an 0470, backpressure sensor circuit error. thats it. we cleand the tube out and checked the sensor. and the code went off but no change. we drained the fuel and cleaned the tanks. and only rust is on the frame. i did not change the cps and did not check icp or ipr. heck i dont even know what that is or where its located in the engine bay. first time to dig into a 7.3. or a diesel let a lone. and i have a very small oil leak in the hpop gasket. could that be a problem.
post #4 of 15 Old 03-17-2014, 07:53 PM Thread Starter
i feel like im in way over my head.and most likely am, but this truck has a lot of mental value and due to my funds i cant just drop it off to get fixed. thank you for any help and teaching me what to do.
post #5 of 15 Old 03-17-2014, 08:09 PM Thread Starter
ok i looked up the icp ipr and cps. im going to replace them tomorrow evening and let you know what happens. thank you.
post #6 of 15 Old 03-18-2014, 07:09 AM
kraker829's Avatar
No problem that's what the forum is for. I'm leaning toward ipr but there are several things that could cause this. You should check and clean every ground you can find while your in there too.
post #7 of 15 Old 03-18-2014, 05:28 PM Thread Starter
How do u put videos on this thing. I checked all 3 sensors. No change so I made a few videos.
post #8 of 15 Old 03-18-2014, 06:08 PM Thread Starter
i sent them to ur email. from my wifes email
post #9 of 15 Old 03-19-2014, 08:20 AM
kraker829's Avatar
Sounds like a bad injector to me. Post this in obs chat so we can get more opinions. I'd do a cylinder contribution test.
post #10 of 15 Old 03-19-2014, 05:22 PM Thread Starter
obs chat? dude i have no idea what that is or how to get to it. i still cant figure out how to get the videos on this forum
