Runs when I plug in, doesn't run when I don't.. - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-16-2014, 05:10 PM Thread Starter
Axlesteel's Avatar
Garage
Okay so it will start right up if it is plugged in but if its not it wont even try to start. Completely clueless. I have checked the gpr and glow plugs all of the harness and everything. The glowplugs DO turn on while in the cylinder when i turn the key. I have put a new starter on it and the batteries are fully charged. I put a new EOT Sensor and a new ICP. What do I do next?
1997 F-250, SD Axle Swap Front and Rear, 4.10 LS, 20x10 -24mm, 35x12.50 Thuderers, E4OD W/ Shift Kit, Upgraded Torque Converter, Upgraded Trans Cooler, Ladder Bars By Me, TS-6, Baby Swamps, 3" DP to 4", 6637, PHP Tuning, Gauges, and A Lot of Lightbars!
Axlesteel is offline
post #2 of 9 Old 03-16-2014, 05:14 PM Thread Starter
Axlesteel's Avatar
Garage
also When cranking the tach moves and smoke comes out of the exhaust.
post #3 of 9 Old 03-16-2014, 05:27 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
How are you checking the GPR and GPs? And what oil are you running?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 9 Old 03-16-2014, 06:38 PM
mjones3586's Avatar
x2 with Rammstein
"Diesel Head and Machinist"
4 inch lift o 36"s
3"DP to 7" Mitre Cut Stacks no cat/muffler
mjones3586 is offline
post #5 of 9 Old 03-17-2014, 02:15 AM Thread Starter
Axlesteel's Avatar
Garage
i have checked the resistance from the gpr and the glowplugs. i have also checked the voltage coming out of the gpr when I turn the key. I have checked and made sure power is also going to the valve covers and they all have 12 volts. Im running rotella T. I had been reasearching and found this article that explains my symptoms and I think could be it. Would you agree? http://swampsdiesel.com/files/7.3LIn...Diagnostic.pdf
post #6 of 9 Old 03-17-2014, 01:47 PM
Chapter Director
Quoted: 5 Post(s)
Read this to compare how you tested. How you explained it seem incorrect but i may just read it differently than you meant
Troubleshooting GPR & GP's
Your oil may be your problem. 15w-40 is way to thick below freezing temps that it wont flow enough to start the truck unless the truck is warmed up(i.e oil is thinner)
I wouldnt jump to the injectors just yet.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 9 Old 03-17-2014, 04:47 PM Thread Starter
Axlesteel's Avatar
Garage
Yes I double checked and have checked them correctly. What oil would you use when its Averaging 22 degrees?
post #8 of 9 Old 03-17-2014, 04:56 PM Thread Starter
Axlesteel's Avatar
Garage
I am here in southern Michigan and the day temp will get up to 50 and the truck will still not start unless plugged in.
post #9 of 9 Old 03-30-2014, 04:56 PM Thread Starter
Axlesteel's Avatar
Garage
Okay quys thought i should get back and show the solution. I had got some baby swamp 150/146 injectors and swapped them with my 230,000 mile ones. Well shell fire right up now. And Im lovin the new injectors btw!!
