rough acceleration - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-09-2014, 06:36 PM Thread Starter
rough acceleration
97 7.3 ts chip quick spool turbo
turbo 5 speed
At a stop light ill put it in 2nd like normal let out the clutch and start to accelerate and my RPMS drop dramatically and sounds terrible and feels worse is it my injectors or a plugged fuel line somewhere?
Swany89b is offline
post #2 of 6 Old 03-10-2014, 06:43 AM
Quoted: 91 Post(s)
Whats your engine temp when this happens? Any check engine lights? Oil in the ICP sensor? I have an auto and a lazy injector so when it's cold it sounds horrible under any load or acceleration but as it warms up its alot better. Hope I can help narrow it down for ya.
White95f250 is offline
post #3 of 6 Old 03-10-2014, 06:49 AM Thread Starter
I have replaced all sensors oil pressure is good epbv is unplugged the only code im getting is for the turbo but i think thats from the boost gauge line, it runs great when its cold then poor when it warms up
Swany89b is offline
post #4 of 6 Old 03-10-2014, 06:53 AM
Quoted: 91 Post(s)
I may be wrong but i've heard that could be a HPOP issue.
post #5 of 6 Old 03-10-2014, 06:56 AM Thread Starter
Do you know what the oil pressure should be at i have a gauge ran to the pump
Swany89b is offline
post #6 of 6 Old 03-10-2014, 07:01 AM
Quoted: 91 Post(s)
I don't but see what the difference is between cold and warm. Someone might chime in with the right pressures.
