Gas Pedal Hesitation - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-08-2014, 11:47 AM Thread Starter
I have a 97 F350 cc/lb. I have noticed that when pushing on the gas pedal I have to push it quite a ways down before I get any kind of response out it (the tachometer needle doesn't even move until then). Is this standard on these trucks or is there something I can do to improve this? Thank you for any help!!
Jakkerus is offline
post #2 of 4 Old 03-09-2014, 07:59 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
There are two electrical items that are part of the pedal assembly:
The Idle Validation Switch (IVS) and the Throttle Position Sensor (TPS). The IVS has a two-wire connection and is a normally open switch and closes just off idle position. The TPS is basically a variable resistor and has a three-wire connection. A quick attempt to fix can be tried by using some electrical contact cleaner on both items. Make sure you do it with the key OFF (better yet nowhere near the ignition). If that doesn't work, you would need to do some investigation on whether it is the IVS not closing just off idle or if the TPS is faulty (resistance change should have no "gaps" while cycled). Ford did not service the TPS and IVS separately. You had to buy the entire pedal assembly. For the TPS, you can try the aftermarket Dorman 699-200 for the 94-97 trucks. The IVS is very hard to find separately. You can try searching for posts by Desert Rancher who posted on a source for it (even then it may not be available). Cheers!
Patrick Feeley is offline
post #3 of 4 Old 07-24-2014, 04:41 AM
Handbanana's Avatar
Was wondering if you ever fixed the hesitation?
Handbanana is offline
post #4 of 4 Old 07-26-2014, 07:06 AM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Standard ign makes the TPS, it also the same as some gas cars and trucks, the IVS you can play with to bring it closer to the pedal, or adapt a micro switch if it is bad.
dirtcrew51m is offline
