96 f250 needs help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-04-2014, 09:18 AM Thread Starter
champaignPS's Avatar
96 f250 needs help
So I changed the o rings out on my injectors and that's when it all started. Truck ran great for the first two days afterwords. Then last Thursday if had a hard time starting. Finally got it to go and made it back home after work. Friday it had a hard time starting once it was going it kept dying out after about a half hour it finally ran ok to drive to work. After work it would start and die start and die. It wouldn't stay running til it got the oil warn eneough. Drive fine til about 5 miles from home. It would not go above 2300 rpm without serious stumble. Now it won't go above 1300 rpm without it stumbling. Help please
1996 F-250PSD, Straight pipe 4" exhaust, 5speed manual tranny. more to come eventually
champaignPS is offline
post #2 of 2 Old 03-04-2014, 04:11 PM Thread Starter
Hi get it started but it won't stay running. Almost as if it not getting fuel. Low oil pressure gauge is showing normal. I am at a loss right now. Any words of wisdom would be greatly appreciated.
