Died while driving? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-04-2014, 06:27 AM Thread Starter
Died while driving?
1996 auto 209k. Had it plugged in and started up like normal, driving to work and just died with no warning. Battery light came on and radio kept playing. Put it in neutral and started right up. What would cause this? Never happened before.
cruisertom is offline
post #2 of 5 Old 03-04-2014, 07:08 AM
Quoted: 50 Post(s)
The two major causes are a CPS failure, and an interruption in the power to the PCM. Did you turn the key back before trying to restart it, or did you just turn it directly from RUN to START? Did you happen to notice if the WTS light came on AFTER it stalled, but BEFORE you turned the key?
madpogue is offline
post #3 of 5 Old 03-04-2014, 02:52 PM Thread Starter
The only light that came on was the battery light. I put it in neutral and started right up. I did not cycle the ignition switch as I was still moving.
post #4 of 5 Old 03-04-2014, 03:01 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Sounds like cps to me.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #5 of 5 Old 03-04-2014, 03:48 PM
Quoted: 50 Post(s)
+1 CPS. Ford or International ONLY. If it fixes it, buy another one to keep in the glove box.
madpogue is offline
