help please! pcm vss cps?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-03-2014, 05:56 PM Thread Starter
hey guys im new here, ive got a 1995, f350 2wd its obdII, its got codes, p0500-vss malfunction, p0603-internal control module KAM malfunction, P0344-CPS circuit intermittent, P0237-Turbo boost sensor A circuit low, and P0470.
The truck started dying while driving or while warming up, now it is having shifting issues, IE hard, late, stalling, and jerking. The speedo isnt working, and the miles arent showing anything, just lighting up. also the od off light is blinking. if anyone could point me in a direction, ive been hearing PCM from some ppl i have spoken to, thanks in advance!
Dave
daves95stroker is offline
post #2 of 4 Old 03-04-2014, 08:50 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
First try a CPS.
CT Performance, Inc. is offline
post #3 of 4 Old 03-04-2014, 08:56 AM
Quoted: 48 Post(s)
Not sure what that means. "Lighting up" could mean the illumination light, or the number itself. Does a _number_ appear in the odometer? If it shows a number, but fails to count up, the PSOM is _probably_ good, and the fault lies with the VSS and/or the wiring from the VSS to the PSOM. Have you removed and inspected or tested the VSS?
CPS is a separate problem; if there's an aftermarket CPS in there, get it out and replace with Ford or International part ONLY.
madpogue is offline
post #4 of 4 Old 03-04-2014, 10:33 AM Thread Starter
There are no numbers, just the background light, n I'll try the ford cps, used advance auto brand n it didn't help, got a vss yesterday, just gotta put it in
