'97 Quit during acceleration, now cranks but no start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-03-2014, 10:55 AM Thread Starter
This morning I was headed to work and decided to stop for coffee. Coming out of the coffee place the truck just quit during my acceleration into traffic. I had let it warm up for 10 minutes before I left home and the coffee shop is only a mile away.
Symptoms are:
Cranks fine
No wait to start light (but it was working before I left)
The tach initially doesn't move on crank but moves slightly after a few seconds of cranking.
Neither an Edge programmer or HF OBD-II code reader can connect.
Fuses seem to be good.
Removing ICP doesn't do any good.
History.
CPS has been replaced but over a year ago.
I recently rebuilt the fuel bowl due to deterioration in the water drain valve o-rings. Has been running a few hundred miles since then.
I got a pinhole leak in the main fuel tank and let it run dry. (I was hoping to drain any water/crud out of the bottom of the tank.) I have been running on the rear tank only.
The truck had been sitting for a while and ran rough. I added some fuel conditioner and ran through two tanks of fuel. Performance went back up and seemed to be running smooth. I also put a few ounces of Lucas oil treatment into the fuel bowl and that worked really well.)
I am thinking the PCM is dead.
Any suggestions?
'97 F-250 HD Crew Cab.
Houston Texas
SpookyDad is offline
post #2 of 5 Old 03-03-2014, 12:48 PM Thread Starter
Just replaced the cps but no change.
post #3 of 5 Old 03-03-2014, 03:41 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Pull allen plug out of hpop see if there is oil in the pump, be careful not to round it out.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #4 of 5 Old 03-04-2014, 08:41 AM Thread Starter
I decided to check the fuses with a multimeter and it turned out the glowplug fuse was dead. Visually it appeared ok. I changed the fuse and the engine started up.
This morning, I went to start it again and the fuse is blown again.
So I am thinking there must be a short somewhere.
I will check the HPOP anyway
post #5 of 5 Old 03-04-2014, 09:31 AM Thread Starter
After some research, I think it may be the heater in the fuel bowl. When I rebuilt the bowl, it looked pretty beat up but since I live in South Texas, it isn't something I really need. Best price I could find was around $65 for a replacement so I decided not to replace it.
