How to disconnect EBPV?? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-27-2014, 08:19 AM Thread Starter
My EBPV, comes on more than it should and is rather annoying , and very loud with a 5inch straight exaust , iv been told i can disconnect it ? Where would I find the spot to disconnect it from ? Help would be greatly appreciated ! Thanks , 7threepowerstroke
7threepowerstroke is offline
post #2 of 5 Old 02-28-2014, 07:48 PM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
I'll assume you mean disconnect it electrically so that it does not actuate. There is a 2-wire weatherpack connector set at the base of the turbo on the driver's side. Disconnect that and it will not actuate. Cheers!
Patrick Feeley is offline
The Following User Says Thank You to Patrick Feeley For This Useful Post:
7threepowerstroke (02-28-2014)
post #3 of 5 Old 02-28-2014, 07:58 PM Thread Starter
Thanks buddy , I'm going to try it Tom , so after disconnected it won't happen at all ?
post #4 of 5 Old 02-28-2014, 07:59 PM Thread Starter
And disconnecting it won't mess with anything else I'm assuming ?
post #5 of 5 Old 03-01-2014, 08:47 AM
Quoted: 9 Post(s)
Nope, it shouldn't affect anything. Cheers!
