Jet sound when cold - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-24-2014, 07:55 AM Thread Starter
Jet sound when cold
I have a 96 f250 7.3 , just recently bought it about 2 months ago, when it's cold, it sounds like air is being pushed out from the exaust and than goes away after a few secound somtimes a min or 2 , than after letting the truck warm up for about 10min , as I drive down the rode it starts to do it again untill I give it more throttle , somtimes it goes away , other times it comes back once I let off. I read about it being the ebpv and when it's cold it comes on to try and heat up the truck. I was woundering if there is a way you can delete it or get rid of it because it's pretty annoying at times and somtimes stays on for a bit and with a 5 inch exaust with no cats or mufflers it's pretty loud
7threepowerstroke is offline
post #2 of 3 Old 02-24-2014, 08:11 AM
Raul@Stealth Automotive's Avatar
its normal.. its your EBPV valve. it helps warm up the truck. you can just disconnect the power from it while its open.
Raul@Stealth Automotive is offline
post #3 of 3 Old 02-24-2014, 08:19 AM Thread Starter
Yes I read that it is normal but was woundering if I can delete it , and where would I find the disconnect for it ? Thanks
