"Water in fuel" light - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-18-2014, 08:21 PM Thread Starter
redstroke97's Avatar
I have a 97 ps and This "water in fuel" light came on my dash but truck runs strong. Should I just change the fuel filter and see if it goes away?
redstroke97 is offline
post #2 of 6 Old 02-18-2014, 08:37 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Ummm..... Yeah man, at least drain the water out of the fuel filter. When was it changed last? Fuel filter are extremely important on a diesel!!!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 6 Old 02-18-2014, 08:54 PM Thread Starter
Ok thanks. I bought the truck about a month ago and I don't think the previous owner had replaced it before. Aren't they supposed to be replaced about every 100k miles?
post #4 of 6 Old 02-19-2014, 03:02 PM
midnite rider's Avatar
Quoted: 285 Post(s)
I changed fuel filter in my 96 every other oil change. There is lever on fuel bowl to drain out the water, iirc it is yellow in color. Someone correct me if i am wrong.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #5 of 6 Old 02-19-2014, 06:29 PM
Quoted: 8 Post(s)
Changing fuel filters every 100K is for gas engines. Diesel engines require fuel filter changes every 10K miles. It's best to do it every other oil change to simply it. But I wouldn't go over 10K miles on a single filter. Also, if you don't drive much change the fuel filter once a year to prevent the filter from disenagrating and spreading throughout the entire fuel system. This has happen to a member on here but he yet several years without changing his filter and when problem arose he went to change the filter and most of the cotton/paper media from the filter was gone!!! Maintainence is very important to the longevity of your diesel engine.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 6 Old 02-19-2014, 06:36 PM Thread Starter
Ok cool. Thank you guys, I appreciate it.
