oil leak past fuel pump o-ring? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-15-2014, 05:53 PM Thread Starter
Recently bought a 97 F250. Ford installed a rebuilt motor in it 3 years prior to my purchase of the truck. I Changed the fuel pump and rebuilt the fuel bowl last weekend due to fuel leaks. No more fuel leaks. However, I notice that there appears to be a tiny amount of engine oil appearing under the banjo bolt in the valley. It appears to be running back from the base of the fuel pump. when I installed the new pump, which came with an o-ring, I was careful to clean the hole where the pump shaft would be seated, and oiled both the o-ring and the walls of the hole. I also was careful not to put the pump in ****eyed as I torqued it down evenly on both sides.
Is it normal to have a little bit of oil come up around this o-ring? It is barely enough to puddle (sometimes just a glaze), so far not enough to run off anywhere out of the valley. Should I be concerned?
Thanks!
Alamo is offline
post #2 of 3 Old 02-05-2016, 10:41 PM
Did you ever figure this out? I have had the same problem for a few months now and it is driving me crazy...
justinnashfs is offline
post #3 of 3 Old 02-16-2016, 10:08 AM
Quoted: 9 Post(s)
Maybe check/re-torque those FP bolts?
97' F350 Crew-LB Original Owner w/203F Thermo; Mag-Hytec Diff Covers + E4OD Trans Pan; WARN Premium Hubs; Custom Rear Over-Load Spring Packs; Amsoil; Remainder = Bone Stock
97OBS7.3L is offline
Tags
fuel pump o-ring
