HELP! Fuel pressure regulator leaking - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-08-2014, 03:53 PM Thread Starter
Ok, so below where the fuel pressure regulator spring is, fuel is shooting out and I can't figure out why… I attached a picture with an arrow pointing to where the fuel comes out.
1997 7.3 F250 CCSB 4X4
TS 6 position chip
3 inch dp to 4 inch to 8 inch stack
Tymar intake
114k miles
lynyrdskynyrd95 is offline
post #2 of 6 Old 02-08-2014, 05:04 PM
midnite rider's Avatar
Quoted: 285 Post(s)
the regulator is fragile, it probably cracked, they have been none to do that.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #3 of 6 Old 02-09-2014, 02:53 AM Thread Starter
is there anyway to buy a replacement regulator? or do you have to buy a whole new fuel bowl?
TS 6 position chip
Tymar intake
114k miles
post #4 of 6 Old 02-09-2014, 05:30 AM
Quoted: 285 Post(s)
You should be able to buy it. friend of mine had his tig welded, said it worked. I might even have one on fuel bowl i removed when i switched over to superduty fuel.
-Tom
post #5 of 6 Old 02-09-2014, 06:39 AM Thread Starter
Ok, thanks so much i appreciate it.
TS 6 position chip
Tymar intake
114k miles
post #6 of 6 Old 02-10-2014, 01:57 PM
Quoted: 285 Post(s)
pm me if u want a used one to try.
-Tom
