96 stuttered and died - Ford Powerstroke Diesel Forum
post #1 of 34 Old 02-07-2014, 12:05 PM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Ok my truck fired right up in the 26* weather. I let it idle until the glow plugs stopped cycling then took off and I was running it at about 2200 rpm's to try and warm it up, then about a 1/4 mile up the road it started sputtering and died. Wouldn't start back just turn over. I had an issue once with the big fuse linked to the bowl heater blowing so I replaced that and after a few minutes it fired up but was running rough. Got it back home and it seemed to somewhat clear up but still not quite right. In the last 2 years I've replaced the cps, ipr, fuel pump, hoop, injectors, ipr wiring harness, and put a Ts 6 pos chip on. Any ideas?
Early 99, 6 speed, ccsb, leveling kit on 35's, 6634, straight pipe, diablo chip.
usramc is offline
post #2 of 34 Old 02-07-2014, 12:11 PM
ADMIN AND TECH
SCUFFY828's Avatar
is check engine light on, if so , get codes pulled , run a fuel pressure test ,next , start here and post back
ITS STOCK
SCUFFY828 is offline
post #3 of 34 Old 02-08-2014, 07:38 AM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
No check engine light. Filter is good. Fuel psi bounces from 46-58. I fired it up this morning and let it idle and it had a bad lope, a few mins in it stumbled and died. I unplugged my chip and it ran the same so I hooked it back up. But after it died the 1 time it ran rough and little by little cleared up and now its idling like normal.
usramc is offline
post #4 of 34 Old 02-08-2014, 07:39 AM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Could it just be that its so cold and maybe all my gp's aren't heating?
usramc is offline
post #5 of 34 Old 02-08-2014, 10:37 AM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Any ideas?
usramc is offline
post #6 of 34 Old 02-08-2014, 01:34 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
how fresh is your fuel?
Trucks and parts............
kanuck15 is offline
post #7 of 34 Old 02-08-2014, 02:28 PM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Last weekend from the speedway. I fuel there regularly and haven't had any trouble. The more I read the more I'm starting to think its the injectors showing weakness. something in the solenoid doesn't get a good connection until the oil is thinned out.
usramc is offline
post #8 of 34 Old 02-08-2014, 03:01 PM
kanuck15's Avatar
Quoted: 10 Post(s)
crappy injectors wouldnt cause an issue this rough. Yeah a hazed idle and whatnot but it should still run
Although your fuel pressure seems kind of low
kanuck15 is offline
post #9 of 34 Old 02-12-2014, 03:26 PM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
I had a the bb mod but it was spiking to about 78psi so I took it out. I replaced one uvch about a year and a half ago so maybe its time to do the other. If I let it warm up it runs fine. I'm stumped.
usramc is offline
post #10 of 34 Old 02-15-2014, 07:52 AM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Well I left it setting all week working out of town and now she's running like a top.
usramc is offline
