96 powerstroke GPR part # - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-24-2014, 04:07 PM Thread Starter
96f350powerstroke's Avatar
I need to replace the GPR on my truck. Problem is that all parts stores, even the ford dealership, only lists the GPR that looks like a starter cylinoid. Mine looks nothing like that. It has two top terminals and an electrical plug on the side. Anyone know the part # I need to ask for? Thanks for any and all responses.
96 f350 powerstroke
6 position tuner
3" down pipe 4" turbo back
Newly built tranny, billet tourque converter, heavy duty clutches, shift kit
Stock motor with 189k
9" lift on 37" toyo M/t's
96f350powerstroke is offline
post #2 of 16 Old 01-24-2014, 04:20 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Save yourself some money and get this instead
Western Plow GPR Relay
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 16 Old 01-24-2014, 04:23 PM Thread Starter
Mine looks nothing like that..
96 f350 powerstroke
6 position tuner
post #4 of 16 Old 01-24-2014, 04:25 PM
Chapter Director
Quoted: 5 Post(s)
Is your truck a California model?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 16 Old 01-24-2014, 04:27 PM Thread Starter
Idk if it is or not. Car fax says its only been registered in Florida. Here is a pic of what mine looks like.
96 f350 powerstroke
6 position tuner
post #6 of 16 Old 01-24-2014, 04:36 PM
Chapter Director
Quoted: 5 Post(s)
Hmm that looks like the goofy relay the E94.5s had. But i thought they got rid of it before 95 someone else could probably explain that better but regardless you can use the relay i linked to you just have to clip the plug off and put some terminal connectors on the end of the wires
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 16 Old 01-24-2014, 04:38 PM Thread Starter
Thanks bud I appreciate the info. If at all possible I would rather just do a direct replacement.
96 f350 powerstroke
6 position tuner
post #8 of 16 Old 01-24-2014, 04:45 PM
Chapter Director
Quoted: 5 Post(s)
Good luck bud I doubt you will be able to like I said they did away with that style in 94.5 and I seem to recall reading a thread where someone said they brought it back one year which I would assume is 96 since you obviously have but don't quote me on that. But all other trucks had the style like the one in my picture on that thread. But hey fords done weirder things
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 16 Old 01-24-2014, 04:47 PM Thread Starter
I understand. If I have to change I will just wanna make sure that's a definite. Thanks again for your help I appreciate it
96 f350 powerstroke
6 position tuner
post #10 of 16 Old 01-24-2014, 04:59 PM
Chapter Director
Quoted: 5 Post(s)
No problem bud definitely an odd situation you have
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
