Starter freezing up - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-23-2014, 12:35 AM Thread Starter
DieselNic's Avatar
Question Starter freezing up
Its gotten really cold the last few days and now my starter will only click when I go to start it. But when I crawl under the truck and jump the solenoid for a second to let it spin then get back out and turn the key it will start. Also When I turn the truck off after running it for an bit then turn it back on it will fire right up. It was a brand new starter two years ago. So I guess my starter is freezing up? Anyone have this problem before?
1997 4x4 Ford F250 7.3L Powerstroke
Dually conversion
Dana 60 conversion
35 lights added
Exhaust Brake
West Coast heated mirrors
Clear head lights
5 inch stacks
3 inch down pipe
33s with 3 inch spacer in the duals
Napa intake
Solid flywheel
DieselNic is offline
post #2 of 3 Old 01-23-2014, 01:04 AM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
Check your wiring from the battery to the starter. Also from the solenoid to the starter. But it does sound like you are in for a starter
Trucks and parts............
kanuck15 is offline
post #3 of 3 Old 01-23-2014, 12:31 PM
Quoted: 84 Post(s)
As stated double check all the connections. Take the battery cables off and clean everything real well. But it might be time for another starter or batteries possibly.
White95f250 is offline
