engine will not start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-14-2014, 04:18 PM Thread Starter
I have a 1996 f-350 with 90k miles on the clock. I just bought the truck. The engine will crank and smoke but will not start unless it is plugged in. We have replace gp relay with oem unit. The wait to start light stays on for 7 to 8 seconds when not plugged in and under 2 seconds when plugged in
Chuck Pierson is offline
post #2 of 4 Old 01-14-2014, 05:02 PM
Glowplugs might be bad, but I definitely don't know for sure, just a guess of what it sounds like could do it
96 7.3 powerstroke, 4.10 gears, 5 speed f350 single cab dually, 3in downpipe from turbo, cat delete and straight piped-SOLD
2001 dodge 2500 2wd auto
7.3kid is offline
post #3 of 4 Old 01-14-2014, 05:19 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
How long are you waiting after the key is turned to WTS before cranking. The glowplugs will be active for about 1.5 minutes (the WTS light has nothing to do with how long the plugs are active ... its just a sort-of reminder). Check the GPs as well. Cheers!
Patrick Feeley is online now
post #4 of 4 Old 01-23-2014, 12:32 PM
Quoted: 84 Post(s)
Mine didn't like to starting until I did the GP's but a new starter helped the most.
White95f250 is offline
