97 7.3 wont turn over, electrical? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-11-2014, 02:56 PM Thread Starter
Bullnose's Avatar
It started like normal 4 times today, then I get in, turn key, WTS light on, radio, heater fans all on, turn key it loses all power, now its acting like batteries are dead, all dash lights are dim, wts light still is on, just very dim. just clicks when I try to turn it over, batteries are both charged up, any ideas on whats going on? its done it a couple times in the last couple years but always started after a couple trys.
E-99 F350 XL 2wd reg. cab 7.3 auto trans all stock 226k
1997 F250 XL 4x4 ex-cab, 7.3, ZF-5 trans 4.10 gears, 3" down pipe, 4" exhaust, 5" tip, 150k
Bullnose is offline
post #2 of 5 Old 01-11-2014, 03:23 PM
Quoted: 58 Post(s)
Bad battery connection, bad connection at starter, bad battery grounds.
Did you LOAD test the batteries, in isolation from one another?
madpogue is offline
post #3 of 5 Old 01-11-2014, 04:07 PM Thread Starter
Bullnose's Avatar
already checked all that is all good....
Bullnose is offline
post #4 of 5 Old 01-11-2014, 04:08 PM Thread Starter
Bullnose's Avatar
already checked all that its all good.....
Bullnose is offline
post #5 of 5 Old 01-12-2014, 08:41 AM
Quoted: 58 Post(s)
That pretty-much leaves the starter. You could eliminate all the low-current stuff (ignition switch, relay, safety switch, etc.) by jumping the starter relay on the fender. If it's a manual, MAKE 100% SURE that the truck is in NEUTRAL when you do this; otherwise you risk running yourself over.
madpogue is offline
