cant prime reservoir - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-10-2014, 11:33 AM Thread Starter
My buddy bought my old truck a couple years ago and the oil cooler went out a couple months ago. Its been parked in my driveway ever since. Oil got in the coolant but doesnt appear that water got in the oil. We pulled the oil cooler off and assembled the new one. He put it on the next morning but couldnt get the last bolt started so it sat until I got home that night and finished it. Between sitting overnight with the oil cooler off and sitting two months with only about 2 gallons in it, obviously the reservoir needed filled. We filled it up and fired it up. Ran until it was out and we tried probably 8 times but still wont stay running. I have a hard time believing a serious issue developed while sitting. Anyone have some ideas?
2007 F-350 4x4 Outlaw
edge juice w/ attitude
MBRP 4" exhaust
6" fabtech on 37" MTs
1983 Porsche 944
white 5-speed
1979 mustang cobra
4.6 32V teksid
road racer/ street car
2001 GSX-R 1000
7t9cobra is offline
post #2 of 6 Old 01-10-2014, 06:41 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
What year is this truck? If it is an early truck, maybe the oil pressure regulator valve parts fell out while you wre doing the oil cooler. The OP regulator is located on the backside (block side) of the filter adapter/header. The early trucks did not have this valve (as well as the filter bypass valve) held in by a snap rings (as the later 96-97 trucks did) and they tend to fall out during handling. Just a thought on my part. Cheers!
Patrick Feeley is offline
post #3 of 6 Old 01-10-2014, 06:48 PM Thread Starter
Its a 94.5 engine. I dont recall seeing anything fall out at all. Unless it fell out in the bed of my truck heading to the shop to clean it in the solvent tank. Any pics on what it should look like?
MBRP 4" exhaust
1983 Porsche 944
white 5-speed
1979 mustang cobra
4.6 32V teksid
2001 GSX-R 1000
7t9cobra is offline
post #4 of 6 Old 01-11-2014, 05:27 AM
Quoted: 15 Post(s)
It doesn't get noticed many times. For some pics, see "this". Note: The one shown is the snapring retained type with the groove for the snapring (but you get the idea). Cheers!
post #5 of 6 Old 01-12-2014, 09:40 AM Thread Starter
Thanks for the help. We pulled the oil cooler off and he felt and said theres nothing in the bore. We couldnt find the parts so hes pulling an oil filter housing off of a parts truck tonight.
MBRP 4" exhaust
1983 Porsche 944
white 5-speed
1979 mustang cobra
4.6 32V teksid
2001 GSX-R 1000
7t9cobra is offline
post #6 of 6 Old 01-12-2014, 10:51 AM
Quoted: 15 Post(s)
Keep us updated. It definitely won't build pressure with those parts missing. Make sure the new header/adapter has the regulator and the bypass valves intact if it is from an older truck. Cheers!
