fuel tank pickup? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-08-2014, 04:02 AM Thread Starter
fuel tank pickup?
I have a new to me 1997 F250 and it has a problem when feeding off of the rear tank. It only seems to be able to use about 8-9 gallons or so out of the rear tank. I am assuming it is a problem with the pickup tube but am not sure. Once I use about 8-9 gallons out of the back tank it start to stumble and when I switch to the front tank it pick right back up. Am I on the right track? Thanks, Mark.
nitz is offline
post #2 of 3 Old 01-08-2014, 04:48 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Yes id say thats your problem, its possible the pickup tube broke higher up. Usually just the foot breaks off and you usually run out around 1/4 tank but i suppose anything is possible
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 3 Old 01-08-2014, 05:32 AM
Quoted: 53 Post(s)
^^^^^ +1; very common. Strainer at the bottom of the pickup tube, aka "showerhead". Pretty sure this is it: http://www.amazon.com/E5tz9j306ba-Diesel-Ford-Sender-Strainer/dp/B0042HBSYE/
madpogue is offline
