White smoke and heavy exhaust - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-30-2013, 09:57 PM Thread Starter
jake1's Avatar
Morning everyone. I have a 97 f350, 7.3 with 248k mi. Especially on cold mornings the trick starts up just fine but leaves a white cloud of smoke and a heavy smell of exhaust that gets into the garage. I have only driven egr and scr diesels on the past so I'm not sure if this is just normal for pre egr motors. Engine has rosewood stage 1 injectors with upgraded ats pedestal with an adjustable Wastegate if that helps any. Thanks in advance
jake1 is offline
post #2 of 4 Old 12-31-2013, 02:42 PM
Arcturus's Avatar
This is normal for cold weather starting. Just idle the truck out of the garage. Plug in the block heater at night or set it on a timer about 3 hours before you plan on driving it.
Read the third sticky post down. It may help
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #3 of 4 Old 01-01-2014, 12:08 AM Thread Starter
jake1's Avatar
Thank you for pointing me to that sticky. A lot of info in there. Much appreciated.
jake1 is offline
post #4 of 4 Old 01-05-2014, 08:12 AM Thread Starter
jake1's Avatar
Plugged in the truck last night, smoke and exhaust was not present upon start up this morning. Thanks for the tip
jake1 is offline
