1995 7.3 has no power - Ford Powerstroke Diesel Forum
post #1 of 21 Old 12-28-2013, 10:23 PM Thread Starter
ztank's Avatar
Hi I have a 95 7.3 powerstroke. As far as I know all that the engine has is ad injectors out of a 99 and a ts chip. When I bought the truck I took a huge shot in the dark because it all of asunden it stoped working while me and the previous owner were talking. I brought the truck home and found out the fuel jelled so I dropped the tanks and cleanded them and put new diesel in. After all that I changed the fuel filter to be safe. Now thw truck starts again with absolutely no power so I replaced the injector harness and pigtails because the drivers side was bad and the wiring was shabby on both sides but I still have no power. It has no power to the four injectors on the drivers side and I dont know if this is because the fuel pressure is low (22psi) which brings me to my question what is causing all of this. I'm thinking it is a bad fuel pressure regulator.
ztank is offline
post #2 of 21 Old 12-28-2013, 10:30 PM
BLT6.0's Avatar
O boy, waft did you pay for that thing?
2004. F250. 4" turbo back exhaust. CAI. EGR deleted. SCT tuned.
BLT6.0 is offline
post #3 of 21 Old 12-28-2013, 10:47 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
You arent getting a signal to 4 injectors? if so thats PCM or IDM
As far as low fuel pressure it could be the fuel pressure regulator but they rarely go bad. Id suspect the pump but you can rebuild or at least clean the fuel pressure regulator screens
Trucks and parts............
kanuck15 is offline
post #4 of 21 Old 12-29-2013, 08:02 AM Thread Starter
ztank's Avatar
I was thinking idm Also and I payed 3 grand. But on the regulator how do I get the spring out to check if that is bad?
ztank is offline
post #5 of 21 Old 12-29-2013, 09:21 AM
kanuck15's Avatar
Quoted: 10 Post(s)
there will be a brass nut. its an 18 or 19mm I cant remember. inside there is a small spring and a shuttle. Those are what puts pressure on the regulator spring itself. A lot of guys put a BB inside the shuttle to stiffen the pressure on the spring. That may be worth a try but dont let your fuel pressure go over 70psi
kanuck15 is offline
post #6 of 21 Old 12-29-2013, 07:41 PM Thread Starter
ztank's Avatar
Ok well the truck is running now but the previous owner must have beat the piss out of it because I was cruising around town in the truck to see if anything would act up and I snapped the yolk
ztank is offline
post #7 of 21 Old 12-29-2013, 11:01 PM
kanuck15's Avatar
Quoted: 10 Post(s)
snapped the yoke? which one?
kanuck15 is offline
post #8 of 21 Old 12-30-2013, 06:44 AM Thread Starter
ztank's Avatar
I snaped the rear yolk
ztank is offline
post #9 of 21 Old 12-30-2013, 07:35 AM Thread Starter
ztank's Avatar
Where can I buy just the spring for my fuel pressure regulator? I don't Need the whole regulator and nor do I want to buy one after the amount of money I have just stuck into this truck
ztank is offline
post #10 of 21 Old 12-30-2013, 07:35 AM Thread Starter
ztank's Avatar
This is the truck btw
ztank is offline
